I have a hall light and a landing light. I can switch either of the lights on or off from the wall switches - one downstairs and one upstaris. These have been working OK for many years.
I want to change one of the switch units for a more modern kind. The old switch box has two on-off switches, one to control the hall light and one for the landing light. At the back of the switch is a single block with six screws ie two ‘common’, two T1 and two T2. I replaced this switch unit with a new one and I was careful to connect the same wires into the same screws (identified as Common, 1 way, 2 way on the new box, (which I presume is equivalent to T1 and T2)). However the new switch does not work ie no light at all. I have not fused anything as the old switch still works.
The new switch unit has two separate blocks of three screws each whereas the old switch unit was an MK type and had one single block of six screws.
Does anyone know how I can get the new switch to work. I have a feeling that a strapping between two of the screws may be needed but I have not a clue where to start
