Help!
23 Jun 2015
Ive a small span ceiling around 3.5m. The joists are nailed to the bearers on installation, but as I was installing a 350l hot water cylinder above, I was advised to install joist hangers for extra protection. Problem is I've used gold screws instead of 40mm twist nails, which I now understand is a big no-no. Can I simply remove the screws and nail in the twist nails?
Any help would be appreciated.
Read more: http://www.diynot.com/diy/threads/help.437207/#ixzz3dvIhLYVX
Which gold screws did you use and why are they a no-no? In general screws are a much more secure fitting the nails but they are more expensive and slower to put in so builders do not tend to use them. Seen the speed of a nail gun?
Frank
4.5 x 50's I think. I've been reading and apparently screws give a better holding strength but nails give you the sheer strength? Everything has been fitted and seems secure, just got a little paranoia! Was thinking of removing the screws and replacing with 40mm twist nails?
Screws are fine. There is no practical difference on performance between 10 screws and 10 nails in a joist hanger.
