Decided to inspect another rental property of mine, and here is what was revealed up in the loft!!!
This grey pedant wire was hanging off a joist up in the loft!!!! Can you believe it, nothing supporting it, just relying on tight connections at the terminals to hold it in place!! The light fitting itself was a fancy chrome one and much heavier than a standard one.
Heres a junction box up there, luckily both the exposed L + N served no purpose in the circuit:
And last but not least, here is no way to hang a light pendant. The green wire you see is wrapped around a nail fixed above into the joist to support the electric cable!! And not only this, the cable then connects to a 13A plug and plugs direct into the ring main!! WTF!!
If only I could go back in time, catch the rascal who did all this!
