My central heating will run for approx 90 mins then the water pipes start vibrating.To stop the vibration i have to turn my thermostat valve in the bedroom 1/4 turn.
This will keep the heating quiet for up to 1hr when the same must be done.
The system has been bled several times with no altertion of the fault(air was not present after the first bleed)
I have recut the joists i can find to lift the pipes off them and even put rubber gromits to seperste the inlet/outlet pies to no avail.
Any ideas or suggestions would help,my local plumber will only come out when the vibration noise is present and as is when he comes the noise had stopped and he would not give any suggestions,just told me to ring next time it happens
