HERE,S ONE FOR THE BOFFINS ON HERE
  • Thread starter Thread starter B.O.B DOLE
  • Start date Start date
B.O.B DOLE said:
chrishutt said:
Pete Chippings? Never heard of him. :?
if you use limescale they will desolve over time and all that acid will then get into the foundations of the house and disovle your house away
keep using the limscale then and watch the house price as well has the house fall in a few years.
I don't follow that. Until they're eaten away, the lime will neutralise the acid. But if you use peat which is itself acidic, surely there will not be the initial buffer of xx years before the acid gets into the subsoil?
I dare say there will be someone alomg who knows how many litres of acid a boiler makes per year, and how long this amount takes to eat away a kg of concrete.
B.O.B DOLE said:
go and drown yourself moron this thread is for the boffins not the morons
I think hes got it mixed up!
Its a thread for morons, NOT boffins !
Those who use limestone ( not limeSCALE ! ) where do you buy it?
Tony
Well stated, moron, but which of your 15 personalities did you mean to be?
TRY ringing up worcester and ask technical they will tell you the same has i am peat gravel chipping are to be used
then we will see who the moron is then oilman
I decided to independently check the MI for the Worcester 35cdi.
This clearly shows details of a condendate soakaway and shows the contents annoted "K". The key for "K" is shown as "Linestone Chippings" !!!
Dont assume that Bob Dole is always telling you the correct facts !!!
Tony
let it drain into a bucket and so evaporate and then it can join its friends in the sky and fall with all the other acid rain. :)
But won't just the water evaporate leaving an ever more concentrated acid solution in the bucket? Eventually it gets knocked over and suddenly you've a ready made pit shaft down through your floor and foundations, just right for a .....soak-away!
