HERE,S ONE FOR THE BOFFINS ON HERE
  • Thread starter Thread starter B.O.B DOLE
  • Start date Start date
Agile said:
I decided to independently check the MI for the Worcester 35cdi.
This clearly shows details of a condendate soakaway and shows the contents annoted "K". The key for "K" is shown as "Linestone Chippings" !!!
Dont assume that Bob Dole is always telling you the correct facts !!!
Agile been on the worcester training 12 month ago and the boffin there told us to ignore the publication in the manu,s instructions and use peet gravel ring them up tomorror and then see who as egg on there face.
Sorry to (acid) rain on your parade!
In between 'linestone' and 'peat gravel' there's some risk of total confusion here.
For a start, I'm sure what was meant was PEA gravel - in other words, fine gravel with pea-sized stones.
And has anyone actually done the numbers to work out how long it would take condensate at (say) 3 litres per day max to react with (say) 10 kilos of limestone (calcium carbonate). I think the answer will turn out to be 'a long time'.
And anyway - why not add some more limestone when the first lot gets dissolved away after several years. Since most of the reaction products will be soluble, the soakaway will be half-empty. (Unless, of course, we start getting high-sulphur gas from wherever we will get it from when North Sea runs out - in which case the state of the soakaway will be the least of our worries!)
If it's looked after like most things, it wont matter whats it's filled with, nobody will ever bother to look once it's installed. Even assuming it's accessible.
fitz wrote:
let it drain into a bucket and so evaporate
But won't just the water evaporate leaving an ever more concentrated acid solution in the bucket?
iirc nitric acid boils at 80 odd so would be gone before the water.
I think I'll market kettles with level switches, for evaporating off condensate. Now how big would one have to be to store enough to use economy 7 at night?
I think I've got an even better idea. How about a boiler that doesn't take quite so much heat out of the flue gases and so avoids condensate being produced in the first place. It would be marginally less efficient than a condensing boiler, but if it was marketed as say standard efficiency it might just catch on. :roll:
Googled on peet gravel and pete gravel. There was one hit on peet gravel by an illiterate on ebay. So basically if BOB can't even spell what he is talking about how can anyone expect to believe what he is saying.
To take up agile's point I was once shown a book that said that hot taps should be fitted on the right. My response was that I could show them 20 where it was the other way round.
Howcome this topic has stretched to four pages? Perhaps we are all missing traineegasman :shock: :lol:
Oh no we are not !!!
I do have to say that I will continue to follow the printed MI for boilers and will not heed some unidentified person who B.O.B. Dole ( not his real name ) met on a course.
Also remember the soak away should be more than 500 mm from the outside wall. CORGI once told someone to move it because it was too close, extended gas safety ???
HO yes you are
you can say what you like till the cows come home but i am wright
HO yes you are
Wilbur or Orville :lol: and I am Buzzzzzzzzz Aldrin 8)
Is B.O.B. Dole really "Trainee gas man" ?
Surely not, his spelling and grammar is a degree better and he is not as abusive as TGM. Although he said "He is wright" ( Presumably he means "right" ).
If I got a written letter from Worcester, do you think that B.O.B. would admit he is wrong ( or "rong" as he would probably spell it ).
Perhaps I should send an email to Worcester as it hardly does their Company a service to suggest their MI are incorrect and allegedly one of their trainers is spreading incorrect rumours?
No, it's a waste of time arguing with him. Boring Old Bloke's problem is not so much getting the thing muddled up in the first place - we've all been there - but his refusal to acknowledge his mistake when in became obvious. Sadly for him he will never learn with that attitude. Let's put this thread to bed.
NO i think that you would be wong
I contacted Worcester today regarding this matter of what do they recommend using in the soakaway from a condensing boiler and their answer
We recommend that it is fitted to the current British Standards, they can be contacted on 0208 996 9001 to enquire on this setup
