Hi All,
Advice would be greatly appreciated.
We have recently moved and are currently sourcing builders etc for a planned extension. My previous house had parquet flooring, we are looking to put this in to the new house. I know its not cheap but following a visit today I have received a quote, details of which are below. Total sqm around 35-38sqm.
I know that costs can vary depending on quality of product and area of the country (Essex, by the way)
Would anyone like to hazard a guess (better still, give an opinion on the cost that should be charged).
I understand that there are multiple variables (we have a screed floor) - you however could consider this to be reasonably basic in shape. There will be no border, the skirting will be removed as will the current tiles/laminate....
Any advice would be much welcomed, especially from those who do this for a living....
How much then
LOUNGE AND HALL
Uplift & Dispose Of Existing Floating Flooring.
Apply 1 Coat Of Wakol D3055 Primer To Improve Adhesion Of All Types Of Sub Floor For All Types Of
Wakol Adhesive.
Supply & Install 12mm WBP Plywood Glued With 'Adesive' PL6 2 Part Adhesive & Weighted To The
Existing Concrete Sub Floor.
Supply & Install Palladio Parquet - European Oak Prime Grade Parquet Battens - 350mm x 70mm x
10mm - (FSC 100% SA-COC-003826) Laid In A Herringbone Design (Tumbled & Distressed) Glued,
Pinned & Rolled To The Plywood Sub Floor.
Supply & Install Oak Flat Bead 25mm x 5mm - Unfinished To Front and Rear Doors.
Sand Flooring To A Fine Finish Including Filling And Apply One Coat Of Junckers Baseprime & Three Coats Of Bona Mega Silk Matt Lacquer.
How much then
LOUNGE AND HALL
Wakol Adhesive.
