oak parquet flooring blocks- glue or nail?
11 Jun 2010
London
hi
I am planning to have oak parquet flooring in my living room and and hallway- (total area 56m2) herring bone style.
Each block measures 360mm x 60 mm x 18mm thick T&G.
The fitter has told me he will have to put treated plywood 4mm -6mm over the exisisting floorboards and he will then secret nail the blocks in and there is no need for gluing.
Further more he will charge £180 a day labour and it will take him 5-6 days.
Is this correct because i have read that parquet flooring should not be nailed.
thanks in advance
arronD
For starters 4 - 6mm ply is way too thin for this project, he/you should use at least 12mm ply (exterior grade), screwed every 20 - 25cm (mind pipes and wires!).
We would fully bond the blocks to the ply with parquet adhesive (F.Ball B92 or Mapei P990) and not secret nail - it's a wood block floor, not floorboards!
Are the blocks pre-finished or unfinished? If unfinished what type of finish does he plan to use and are the materials and time this will take - sanding and applying finish - included in the price/days he thinks it will take?
