hi-spec j25 problem
8 Jan 2011
Liverpool
my hi-spec j25 main burner will not light i connected a light switch to the thermostat and nothing happened so i take it that the thermostat is not the problem. the timer is set to the on position and the pilot light is lit. is there any other tests/repairs i could carry out.
You could check that the electric "Call for heat" is there. That's about all you could do now though.
Check that the gas control knob has been turned from pilot ignition symbol
to main flame symbol.
