I've been to look at a job. It's a new radial circuit which requires high integrity earthing.
The circuit is to be supplied from a DB which is a submains fed in 2 core SWA.
This DB supplies some circuits in an existing 3x3 steel trunking, and there are some other circuits supplied from another DB about 6m away.
As the trunking links the earth from the two DBs together, I'm thinking this DB should be ok to supply a circuit requiring HIE as even if one of the earths was to fail, the circuit will still be earthed.
Does this sound right? I could run an additional earth from the main DB to the sub DB but the incommer is in the cellar and the sub DB is on the second floor and there is no riser, so I'd prefer not to.
