High electricity usage in empty flat
29 Dec 2017
Scotland
i got the keys for my first home 2 and a half weeks ago and took opening meter readings the day I got the keys. How today I noticed the meter had went up 38 units in the space of and a half weeks even though the property is totally empty. The only things using electricity at the moment are 2 mains operated smoke detectors and a outside light which is on a sensor. However I doubt they would use 38kw of electricity in such a short period of time.
Any ideas??
Is it a big 500watt flood which gets triggered too easily(i.e. by the wind even)? On for 4 hours a day over 18 days comes to 36kWh(units) exactly.
Next door's growbags?
Check the loft space too.
No it looks like a compact fluorescent fixture beside the front door (although a neighbor did tell me it’s flickering so presumably needs the bulb replacing)
please photograph your consumer unit and your meter for more clues.
until then
does the meter have a rotating disk? Is it rotating?
Or a red LED. Is it flashing?
Leave the lights turned off as if it was unoccupied when you check.
BTW I have a thermostatically-controlled anti-frost heater to prevent pipes freezing in my garage. Is it cold where you are?
Ordinary porch lamps or security lamps use trivial power as long as you have LEDs or energy-saving lamps in them.
Is there an immersion heater?
Well take the bulb out for a start.
But CFLs can flicker due to tiny electrical pickup in the cable, so it might not be a faulty bulb.
This causes them to briefly flash on every few seconds to once in a couple of minutes, depending on the "leakage." It is usually not due to a fault but to an interesting wiring effect. In this case, electrical usage is tiny.
Good thinking, a 90 watt bulb on continuously would give about that usage. 0.09kW*24hours*18days = 38.88 units
If you have a clamp meter or can borrow one, you can find out which circuit is using these watts and go from there.
Unfortunately I won’t be back there until Wednesday but I will take photos when I get there. The property has a gas combi boiler (which is unplugged at the moment) so I doubt it could be a immersion heater.
An immersion heater is nothing to do with a gas combi boiler. Is the water hot at the taps?
or by observing the meter while turning MCBs on and off, or removing fuses.
