Hello,
We moved into our current house in November 2013. Since then, we've been getting high gas bills. E-ON says we use 85% more gas than similar homes.
The last bill for 23 days using actual start and end readings shows that we used 2003 kWh worth of gas (179 m³) which cost £95. That's 87.09 kWh/7.78 m³/£4.13 per day.
It's a 3 bed semi-detached house (3 adults) with 10 years old Combi boiler. Gas is used for central heating, cooking (oven hob) and hot water.
1. Central heating:
The external thermostat is broken and only works in full position. I set it to full (>25C) and decided to use the boiler thermostat instead. I set it to the lowest position on the dial. Any lower would put the boiler in 'summer mode' and it wouldn't fire at all. The thermostat is at the same temperature pretty much all the time because all of us have different work shift patterns so there's always somebody at home. All radiators are set to full. It isn't cold in the house, but it's not as warm as we'd like. Definetely colder than we're used to.
2. Hot water:
Only 1 person uses gas to heat her shower. The other 2 use electric shower.
When that 1 person is not showering, the hot water temperature on the boiler is set to minimum (it's barely warm when doing the dishes).
3. Cooking:
We cook pretty much every day.
Does this consumption seem reasonable? I don't mind the high bills if that's what we're supposed to get. I'm just trying to make sure eveything's right since these bills are much higher than we're used to. I read that an average energy consumption (electricity + gas) varies from £800 to £1200 per annum. I paid £600 for the last 3 months and huge majority of it is for gas. According to EON our electricity usage is 2% lower than similar homes.
I'll be doing some testing tonight checking how the gas meter behaves when the boiler and oven are on/off.
Thanks for spending time to read this.
Regards,
Kam
1. Central heating:
2. Hot water:
3. Cooking:
Regards,
Kam
