Hi all,
I want to put my network and CCTV gear on a non-RCD circuit along with the Alarm system.
I currently have an alarm system fitted, which is on its own 16A non-RCD circuit, with the control panel in the under-stairs cupboard. I want to locate the network switch and CCTV recorder in the same location on the same circuit.
The alarm control box is fed directly from the consumer unit, with a 13A fused isolation switch on the wall just before it. Would it be acceptable to directly wire in a 4-gang power strip from the load side of this isolation switch?
Cheers.
Cheers.
