Hi All,
I am trying to help my dad mend his Historic Tram. The tram has a dewirement indicator consisting of a 600 volt DC supply and a rather ancient coil and relay contacts. Anyhow, the coil has burned out and you cannot get them anymore (1948 British Thomson Houston). I am trying to figure out what voltage the coil would have been.
You have the Positive 600 volts coming in through a 5 amp fuse and then through a 9K ohm resistor, and then onto the positive side of the coil.
On the negative side, you have the O volts also going through a 5 amp fuse, and then through another 9K ohm resistor onto the negative side of the coil.
My question is, How can i work out what the coil voltage originally was? I am getting ridiculous figures and values when doing ohms law and voltage drop calcs - a 540 coil surely is not possible?????? can anyone help me out?
