Hip roof joint
16 Jan 2010
Oxfordshire
I'm building a 4 sided hipped roof where the top half is glass and the bottom half will be tiled. Having exposed rafters I'm looking for a way to connect the 5 visible rafters that meet the ridge - the 3 common rafters and the two hip rafters. How do I fix all 5 onto the ridge at the same point? I'm hoping there is a bracket available somewhere that I can bolt across the two side rafters and the ridge end so that the other three rafters can sit on to it. Any ideas?
View media item 26291
This is a diagram I've cribbed from another web site. It's pretty much self-explanatory. The three common rafters are simple mitre cuts and the two hip rafters are compound mitre cuts.
We normally fix a plywood gusset plate to the common rafters prior to measuring and cutting the hip members.
This is so that the whole of the plumb cut on the hips is collected by the gusset due to their deep section.
Exposing this part of a roof is going to require some pretty skilled joinery.
Simpson Strong-Tie do a bracket for hip and rafter connections, have a look at their site to see if any are useful
Many thanks for your helpful and quick replies. Redherring's drawing shows my roof exactly. BUT none of the web sites I've looked at shows how the 5 rafters are joined together, hence my earlier question as I want to avoid 5 nails/screws from interfering with each other and severely weakening the timber. noseall's gusset sounds OK if the joint is not visible although I suppose I could stain such a plate. I couldn't find a hip joint connector at woody's suggestion of the Simpson Strong tie site - I'll 'phone them tomorrow. What I have done is to bolt the two common rafters together through the ridge and that is so much better/ridged than screws or nails. Any other ides?
Here is a slightly different arrangement at the ridge, which might give better fixing
But remenber that the rafters are merely pushing on each other at this location so only really need to be spiked and not have some elaborate fixing
Would you not be better off closing the very apex off with a small collared ceiling, thus only exposing the straight runs and not the 'busy' junction at the ridge etc?
Don't conservatory roof have some sort of plate to hide the junction at this point?
I'd agree its going to need a good chippie ....... or a big tub of filler
Thanks again for your comments. Woody's point about no need for a good fixing as all rafters hold each other up is just what my structural engineer said. That's wonderful in theory, BUT in practice if the ridge is not held securely, movements caused mainly by clambering around on the roof cause everything to move so I want some security that when I start to lay heavy sheets of double glazed glass that a sheet is not going to fall through!
noseall's point about a small ceiling can't be used as the exposed rafters and ridge are to be a feature.
Ok, so why don't you fit some horizontal stunted collars (in line with the rafters) then plasterboard between these. It will look as though the rafters form a kind of flat topped triangle.
You are going to have to infill at some point are you not?
Insulation, plasterboard....?
