- Joined
- 15 Jun 2020
- Messages
- 7
- Reaction score
- 0
- Country
ever since I had a new condesing boiler fiited, whenever I run the hot water tap in my kitchen or bathroom I start to hear hissing coming from a cold water pipe. This pipe runs from the attic, straight down through the floor of the airing cupboard and the noise sounds like it's in the pipe. A couple of minutes after the hot water tap is closed off the hissing stops and the water stops running through the pipe.
is this something to be concerned about? Or perhaps simply an excess of pressure due to the new boiler, but also why is the cold pipe hissing?
I have a hot water tank, so it's not the cold going to the boiler to heat up as it would in a combi boiler.
I also dont use too much hot water, so the tank is usually very low, could this also be a reason?
thanks in advance.
thanks in advance.
