Hi everyone. In a bit of a pickle and sorry for the long post. My elderly mother in laws boiler broke down and she managed to get someone in to take out existing system which had a Seperate hot water tank.
She has had that replaced with a New Combi boiler and tank etc has been removed. She already had a hive system but it has a double channel receiver. Engineer has fitted boiler and connected it up to that. He's then left and is now working away and I can't get hold of him. I've been over and checked and the boiler is running 24hrs. In short the hive is connected but its not controlling anything.
I've read this forum and in here (https://www.diynot.com/diy/threads/hive-wiring.553481/) it's suggesting that you cant /shouldn't wire up a non combi hive to a combo. I've looked on line and can see that there are two Seperate versions one for Combi one for water and heat.
Can I just replace the hive and buy a single channel receiver and change the wiring?
In short term boiler will have to be turned off and on as house will get too hot. Its not ideal as she is disabled and unit is in garage.
