Hive mini without smart hub
5 Feb 2007
Liverpool
Hi
If you have a system boilor with a honeywell wireless analogue dial thermostat.
With Drayton controls wired by the cylinder for hot water and also turn heating on.
If I got the hive mini installed without smart hub . Would I still be able to control hot water or does the mini override it.
In other words do you need smart hub to be able to turn hot water on amd off ?
If the hive mini gets installed and this Drayton controls are left in.
Would the hot water still not work without hub by just leaving the hot water set to on via the Drayton settings ?
