Hi, so I've fitted a hive thermostat to my baxi combi boiler and all was working fine. Unfortunately the hive thermostat is no longer firing the boiler, the stat is communicating with the sender and the green light is indicating its switching on but no response from the boiler.
On further investigation I've found the boiler has an internal sender to a old wireless room stat, I'm thinking this is preventing the hive from working, but not sure why it was working previously.
Question I have is should I disconnect the internal sender completely, or should I just link the 2 black switch wires, I'm assuming this would make the boiler ON and then the hive should take control, pic of internal sender attached thanks for any advice
