Hole Cutting help
30 Mar 2007
Staffordshire
Hi all...
I’m in need of some help cutting a hole in a ceramic tile I’m laying in our downstairs loo.
The waste pipe for the toilet is in the concrete floor and typically in laying the tiles out square to the room before fixing them, I’ve found that the toilet waste falls onto a full tile. I would ideally not like to cut the tile in half and do half cuts..
I’m just wondering if there is a way anyone can suggest of cutting the hole as a full circle. It a rather late hole so didn’t know if there was a hole saw big enough on sale.. Any suggestions would be massively appreciated..
I use either a 4", 5" or 6" core drill depending on the toilet fitting.
If the toilet is not really manoeuvrable because it's cemented in, I would have laid the tiles so the grout line hit the toilet so you can cut the shape out of the sides of 2, 3, 4 tiles etc..
You don't need to cut the hole in one go, you can use a small hole drill around the perimeter then join with a marking tool and break out the center carefully.
You don't even need a round hole you could cut it square as loo base with hide.
+1 for this method. Or maybe time to break out the carpentry skills and box it in to avoid the cut ;)
