Hi guys
I have a problem with the splashback behind my gas hob. The wall bows out so that the glass panel is raised (pushed away from the wall) by about 1cm all round the edges. This looks unsightly and reduces an already very small gap between back of hob and panel, making cleaning difficult; also the gap means that dust, insects etc can get in behind the panel. So I plan to replace the glass splashback with a stainless steel one – this will look better .. I had hoped to be able to pull it/stick it/screw it flush but I am advised that a steel panel cannot be so ‘warped’ so here is my plan:
the wall is breeze on brick with plasterboard dabbed on (gap of about 4cm – not sure if battens are used .. but behind the splashback area seems to be just air thankfully) ~ I intend to cut out a central rectangle of plasterboard, to within roughly 5cm of the splashback edge – then using grab adhesive the panel will be flush on all the edges and also be flat – job done‼
Can anyone see why this might be an undesirable solution? Effectively I am replacing plasterboard with steel and mdf .. I can’t see any issue so long as I ensure that the seal is airtight so brick dust doesn’t blow through to the kitchen.
Thanks for any advice as this seems rather unusual!
