Holes in roofing felt
30 Jan 2011
Middlesex
I finally had a look around the loft in my new (old) property and saw a few decent-sized holes in the roofing felt that exposed the roof tiles. The holes are around 6" in diameter.
Could these holes cause a leak into the loft floor? Or are roof tiles interlocked to prevent water seeping through?
If leaks could happen then how could these holes be repaired?
The tiles/slates is the 1st line of defence against water ingress, there are thousands of roofs with no felt at all.
the water can come in if there is a broken, slipped tile or slate above any breaks in the membrane.
I appear to have a damp patch on the landing ceiling (just at the top of the stairs). I'm not sure if it's a water pipe leaking or water dripping from the roof.
The loft is being cleared out next week so I can get someone in to check the roof out and repair it if necessary.
