Hi - I’ve recently had a new parquet floor laid in a dining room (22mm oak, t and g, planks are 230 x 70mm)
it’s been done professionally and I’m finishing it off and doing the edging.
The question I had is that it looks great but there are two noticeable areas where a couple of planks have a hollow sound if you tap them and a small creak when you walk on them. My guess is that there’s either a slight change in level under them or not a full bed of adhesive - or both.
is this going to be a problem in years to come and if so, is there any way to fix it? I can’t see an easy option as they’re in the middle of a 30sq m room with t and g planks so can’t see how to lift them without ripping the whole lot up.
thanks for any advice.
