You woudn't use a PCB relay which had a "5V output". You would use the contacts of a relay (which had a 5V coil) to switch a 12V power supply which then fed the 12V coil of a secondary relay.In terms of using 5v relays to switch a 12v supply to the DIN mounted relay, how would this work in practice? The bit I cant get my head around is what exactly goes between the 5v output of the PCB relay and the 12v input on the DIN mounted relay??
Not that I'm aware of, but that means nothing, since I'm anything but an authority in relation to such matters. Others may be able to help.My question regarding the dimmers may be a bit of a naïve one. I thought there may be 'intelligent' DIN mounted dimmer modules that could have, say, three circuits connected and I could send a message to an input that would control a specific load - is there such a thing?
Is that not now a DIYnot 'Home Automation' forum or something like that? If so, that would probably be the place to get informed answers.
Kind Regards, John
