Honeywell ATC928G2000
4 Jan 2006
Leeds
I recently got an ATC928, all work as it should, apart from one annoying niggle.
Every day it "looses" connection with the boiler relay.
10 hours later is "regains" connection.
Thing is, it doesn't, it still works as it should.
so far, it has done it every night without fail, and it does it 10 minues later every night.
Ie night 1, lost connection at 0000, regained 2000
night 2 lost at 0010, regained 2010
night 3 lost at 0020, regained 2020
I ve tried resetting everything, and resyncing (including resetting the boiler relay, not just resyncing)
Currently its set up as just a room stat, once ive got this sorted ill be adding the remote rad stats etc to the system.
I'll post a pic tomorrow when I got home, not sure if that is an issue, it's been working fine with the old cm921.
I went to a customer the other day to rewire their evo system (fitted by an elecitrcian).
He spent nearly 10 minutes pontificating on what he thought the problem was.
I spent 20 minutes rewiring the receivers so they were as designed.
then another 20 minutes setting it up as it was supposed to be.
What you think isn't an issue has nothing to do with it.
Hope you erased the receivers memory before fitting the Evo controller.
