Have had the wireless Honeywell CM 927 for nearly a couple of years now. Works well and generally pleased with it but there is one thing that puzzles me and I'm not sure it's working correctly. Whenever the tempaerature is hovering around the programmed temperatures or set points I have noticed that the boiler cuts in and out for very short cycles ( 1-2 minutes). The length of time the boiler is working there is definitley no impact on the room tempertaure the stat is in itse,f so why does it come on and go off ? Boiler is Baxi heat only, hot water controlled by cylinder stat. CM927Stat is in temperature stable environment ( not in draughty location). Everything else fine . On start up/set point changes stays on until up to correct tempertaure no problem . Only happening when maintaining temperature but I know the hot water hasn't even made it to the rad, let alone change room temp to cause the switch off, so is it a false switch on reading? Any one any ideas?
