Hi everyone... I wonder if someone can help. I have a fairly old standard gravity fed system. It is a Ideal boiler with a lifestyle 722 controller for hot water and heating with a separate mechanical room stat. Last week i had an electrician replace the room stat with a honeywell cm907 programmable room stat. I noticed a year or so ago (before replacement) that my heating would only come on when the hot water was on. Since replacing the room stat i have noticed that the heating only comes on im this sequence... Put the hot water on... Put the heating on... Then switch the hot water off. Then once he heating is running if i switch on the hot water it wont come on unless the heating is first switched off! The other unfortunate side effect i have noticed is that the boiler spur fuses sometimes when the desired temperature is reached on the programmable room stat.
The electirician was round today with a plumber to look at things.m the plumber is saying the all the zone valves are working and the problem must be electrical. They are suggesting that the lifestyle 722 and the honywell prog room stat are possibly conflicting? Is that possible - i would have thought that the prog thermostat is simply replacing the old mechanical thermostat. They reckon that the lifestyle controller might have to be replaced with one that controls hot water only?
Any advice gratefully received. Thanks.
