About 4 months ago the room thermostat started to click ON and Off just like a 'Metronome', clicking approx once a second. After pressing all user controls, the only way I could get it to stop clicking was to remove a battery.
I checked the batteries, they were 1.5V each. I changed them for good measure. Again a month later the same happened again. Battery voltage ok. ( I tested them under load and they held 1.47V). I did think the supplied batteries with the stat might be elcheapos?).
Whilst the clicking was going on, I could hear the circulating pump going ON/OFF to suit. Pulling the 5amp plug on the pump did not cause the roomstat clicking.
For good measure I telephone Honeywell to enquire about the fault. Seems they have no records of other customers reporting similar problem.
The clicking started up after a few weeks again.
Anyway, I changed the DT90E for good measure for the same model again. Only to find the problem occured today after nearly 3+ weeks with the replacement.
Has anyone got any idea what the fault might be? I can't get the fault to show itself again but did video it performing it quirk.
Tomorrow I will put in some Duracells for good measure!
Thanks Alan
Thanks Alan
