Honeywell DT90E
5 Feb 2012
Somerset
Hi All, applogies that variations of this question have already been asked, just not quite my setup.
I'm replacing an old rotary room thermostat with a Honeywell DT90E.
Old thermostat had a permanent live, switched live (by the thermostat), neutral and earth.
The DT90e is a two wire stat but it has three terminals as follows
A marked live in
B seems to be a neutral
C seems to be the internal thermostat switch
I see there have been other posts but not quite the same so any advice which of my four wires go where please?
Thanks.
A live, B switched live, make neutral and earth safe as not required.
Thanks both, I had seen that post but hadn't appreciated that com was the permanent live. Now all working as advised.
