My first thread, hopefully many to come.
So for a while the CP038 keypad backlight has been flickering- going up and down in brightness and now it's settled to a dimly lit display. The keypad works fine, it's just that the display as it's not lit as before has become a little difficult to read.
My question is-
Can I enter the engineer code into the Galaxy 2-44, remove and replace the keypad with a new one? Would I need to re- program this in to the panel or is it a swap out job? If I need to program this in first then remove the old keypad how would this work? Would there be any 'catch outs' as no keypad means no way to communicate with panel.
My second question is-
Is there a option to not have the keypad backlight turn on all the time, only come on when a key is pressed? Then turn off after a few seconds when the last key was pressed? Does this functionality exist?
My question is-
