Honeywell ST9420c to HIVE 2
18 Apr 2017
I'm currently looking to change to a HIVE system. At present I have a Honeywell ST9420c timer with wireless thermostat and wireless cylinder stat. I believe that I have a Y plan system as I only have one 3 way port and a pump.
At present the Honeywell timer ST9420c has the following wires:
  • Blue (neutral)
  • Brown (live)
  • Black (HW Off)
  • Grey (HW On)
  • Yellow/green (CH on) - bad practice to use earth, I've just found it like that
Boiler Model: Worcester Greenstar Ri
Questions:
1) Can I simply swap out the timer for the HIVE 2, even though I don't have a CH off?
2) Can I simply remove the wireless cylinder stat without replacing it?
Thanks for your help, I've attached a couple of pictures to help.
Hi JLB90, how did you get on with this in the end? I'm about to do the exact same thing (once the Hive is delivered) so sharing your experience would be a great help. Many thanks
