Honeywell T6360 Thermostat
18 Jul 2007
Just fitted a Honeywell T6360 and notice that the alignment of the knob is not correct, i.e. it's about 4 degrees off where it should be...
Now I've noticed you can pull off the knob and fit it in pretty much any position... But how do I ensure this is fitted in the correct position?
If you want it spot on you have no chance you will get it to within a couple of degrees though . use a proper digital thermometer to take room temp just beside the roomstat.
Take knob off and turn internal spindle slightly till it clicks then put knob back on lining up temp(you have got with digital thermo) on knob with the line on the cover.
Or do what everyone else does and guess it most people get it about right
Ok :D guess I'll stick with it until I get the spare cash to buy a programmable thermostat
Its totally irrelevant what the exact reading is showing.
You just set it to the position which gives you the temperature you require.
Tony
Tony is spot on when we used to do local authority contract we would get loads of calls every year i have to turn my stat to 25 to come on it must cost me money to have it that high ...take knob off put it at 15 ...Thats a lot better house better/lower temp and saving me money.....House was exactly same temp but knob said it was lower
