- Joined
- 30 Aug 2018
- Messages
- 2
- Reaction score
- 0
- Country
I am after a bit of confirmation from the people in the know. The more I think about it and run through it in my head, the more I doubt my logic and start to ask more questions of whether my thoughts are indeed correct! I have a new Nest 3rd Gen wireless thermostat that the boss has bought. This is to replace a Salus wireless thermostat that is rubbish and has been since we moved in two years ago. It keeps losing connection with the receiver, no matter how close it is placed to the receiver and its getting very annoying. Well it will be when the heating is back on and I get calls at work from her saying the house is cold! Hence why she has bought the Nest.
Now, as I understand it, the nest will sort heating and hot water, so we can do away with the Honeywell ST9400 programmer, which again could do with some tlc. The clips for mounting on the back plate are either broken off or cracked so it is prone to being dislodged by towels etc if the airing cupboard is being used, another source of “I have no water or heat” calls!
Now I have looked at the wiring diagrams etc for the nest and other existing components. Every time I think I have sorted the replacement, I doubt myself and start over the thought process. Could someone out there confirm what should be fed into the Nest heat link box please? I have sketched out the current set up, it will be a good opportunity to tidy up the wiring that is so jumbled at present it took some deciphering to get the sketch!
I should add that the Nest is replacing the Salus wireless stat so will be wireless to the heat link box as there are no existing stat wires.
Ben
