I have a Y plan system and whilst the HW works, the CH doesn't. So I put the valve on manual and now, of course, the CH is on when the HW is on. I pretty sure it's the valve that's had it. I say this as the wife confessed that she'd given the valve a bit of a knock whilst in the airing cupboard - and then the problem started.
I'm about to start on the replacement and had a look inside the powerhead which is basically the motor and a PCB. My question is really how to approach the job - would it be better to change the powerhead or just try the swapping out the motor first? If there are any electrically tests that need doing, I'm happy to get the multimeter out.
Thanks.
Thanks.
