- Joined
- 13 May 2024
- Messages
- 5
- Reaction score
- 0
- Country
Tecently noticed that the hot water is only working if there heating snd hot water demand.
Valve is position A for heating and is ooening hot water position B.
With both heating and hot water flow goes into both sides.
The system is y plan. I fsrly new to the house and had new boiler with google nest controller installed.
They left the honeywell and cyclinder thermostat in place.
Often some testing I have.
The V4073A1039 model 3 way valve seem to parked in position A.
It nest controller commands hot and cold flow goes in both A & B. With hearing satisfied boiler goes on/ with heating demand.
The hotwater timer doesn't move the valve to hot water only.
The motor housing on the valve is warm even there the pump is off.
Hot water from nest programme turns pump but not the boiler. Which eventually stops despite being commanded on by the timer.
If I push room thermostat up to high enough create demand on the flow goes into both sides untill and boiler fires to provide heat.
The cylinder loks fairly old and simple L641A1005 unit. It does click If push the bimetalic strip.
questions
1 Does 3 way remember the last actuated position?
2 as mid shouldn't always from the mid position?
3. Finally is return spring internal the actuator or valve body?
I suspect that the cylinder thermostat is at fault in that it's sending demand signal.
If unit is a compatible replacement?
questions
