I have a Hoover upright cleaner model 1900w, that cuts out after 5 mins
use then takes 20mins to start up again. It appears to be getting too hot
but after 5 mins???
Clean out filters and pipework. the motor uses the air that passes through the machine to cool it self, if the filters or pipework are blocked or restricted the motor can not cool.
1900W running for 5 mins, take a look at your kettle rating or your oven element, motors can get hot very quickly without adequate airflow.
