After much investigation, I have narrowed this down to the pressure switch / chamber; I can get the machine to spin if I remove the hose from the pressure switch, so it would seem to indicate a blocked chamber.
I have tried washing program A (90 degree) with a cupful of Soda Crystals to clear the blockage as suggested elsewhere, but this has not fixed the problem. The pump appears to empty the machine and I only get 2-3 pints out if I take the discharge hose off the back.
If I remove the pressure hose from the pressure switch end and then blow down the tube, it is obstructed. Should I be able to blow down it freely, or is there a diaphragm somewhere? I have watched the chamber during a wash and cannot see any water in it, so I guess it is only a matter of time before I suffer an overfill .
The pressure chamber itself has a yellow hose going up to the pressure switch at the upper end and a short, black hose going into the back of the drum at right angles at the other. I cannot see this part on any of the spares sites, so would like to remove the existing and refurbish it (if I can).
Any help and guidance / instructions greatly appreciated.
Richard
Edit:
Just searched eSpares again and found this part, which looks correct. Just need to get the rest of the bits which connect it to the drum.
Still grateful for any gotchas I should watch out for
Richard
Edit:
