my hoover condenser dryer worked perfectly until today. the filtercare light stays illuminate even after the filters have been cleaned and also the dryer no longer gets hot.
i have checked connectors etc, but found nowt.
Either the heater element is open circuit or toc open circuit.The heater is found by removing back panel-new heater looks slightly different to some older ones where they replaced thermal fuse with two stats.
