Hoover washing machine error
16 Jun 2024
Hi all, I have a washing machine that constantly fills with water after a cycle. As soon as I start a cycle water keeps filling the drum constantly even on a spin and drain cycle. I have replaced the water level sensor and cleaned the inlets so know there is no grit or anything?
What's my next move to try and fix this issue?
Tia
If it only happens when the machine is switched on then it sounds like the water inlet valve is jamming open or getting a constant electrical supply. Disconnect it and see if that stops the water flowing if not then you have a mechanical problem and it will either need to be stripped cleaned and lubricated or replaced. If it does stop flowing when disconnected the problem could be that the pressure sensor that you have replaced is not being actuated, usually by a blocked pipe or drain pump, if it is connected to the pump, or similar if it is fixed to the back of the drum.
