Hi folks
I'm hoping one you very knowledgable folks can clarify a couple of points for me.
I'm having a single storey rear extension built at the moment on our living room. The extension will be used as a dining room. The builder has been contracted to put up the shell only.
Due to building on the boundary line, the internal wall of the extension causes a dog leg in the wall (see attached image) where the extension attaches to the main house. The dog leg will be around 15cm in total once boarded and plastered.
View media item 31420
I'd like to install 3 x 2G sockets into the extension, and would like to use horizontal cable runs between the outlets. I've looked at a few docs on this site and online and I can't seem to find clarity on whether horizontal runs are permitted to continue around internal corners?
If so, this brings me onto a second question. The socket I'd use to break into the ring is in the living room around 40cms from the corner which now joins onto the extension.
Would a horizontal cable run be permitted around a dog leg in the wall formed by the inner leaf of the extension wall?
I'm more than happy to install vertically if this is a better solutions, but if it can be ran horizintally it would save a little work (and a lot of cable).
What are your thoughts?
Thanks again for your help.
