Hot Cup = Heat Stain (in Ducal Top) = Dog House
11 May 2004
Hampshire
..so I didn't think, etc. :oops:
Is there a trick to get the heat stain out of the wood? This is below the varnish finish - so doesnt seem obvious to me at the mo.
Can anyone advise?
Topps* Ring.Away
No idea how it does it, but it works.
No idea if you can still buy it, my little tube is at least 30 years old when I come to work it out :shock: :shock:
But it still works.
not sure what you mean by 'ducal' but i do know a way of getting heat rings out of varnished or french polished wood.
mix some cigar ash with water to a thick paste and smear it on the ring, it works a bit like a stain - will make it almost invisible. then if the polish is damaged use a little wax just over the affected part, let it dry a bit and then polish it. the ash must be from a cigar - ive only tried it with fat cigars - cigarette ash doesn't work.
sounds weird but it really does work
fag ash and olive oil will do the trick mixwd into a paste
Thanks for the advice. Very interesting idea.......
Please see below for the degree of <ahem> success :shock: I had with the cigar ash and (olive) oil approach. These photos were taken after the application. The improvement is unfortunately nothing.
I would be grateful for any further suggestions. I suspect the varnish layer is prevent the stain having any effect - but perhaps my application technique is not suitable? Any ideas welcome :roll:
(I havent found any web references to Topps RingAway.)
David P - Ducal is(was) a furniture range manufactured in Andover, before they went bust, that is. Style pretty much as the photos, as I recall - apart from the heat stain that is.
The coaster near to the stain is the one I *should* have used :oops:
