- Joined
- 13 Jul 2015
- Messages
- 9
- Reaction score
- 0
- Country
Hi Guys
I'm about to install a hot tub in my garden, but need some advice regarding the required cable size.
I have already checked with two local electricians, and both have offered different advice, so hence asking on here.
Also, depending which I use, online calculators suggest either 6mm or 10mm
The cable run to the hot tub is about 45m, I already have a 3 core 6mm SWA cable feeding the garage (next to tub) and I am wondering if I can use this or if I need to run a second feed using 10mm cable.
The tub specs show three power options
15A, 23A, 29A
The lowest setting disables the heater whilst pumps are running, the middle allows the heater when one pump is on, and the highest allows everything to be on simultaneously.
So 29A is worst case I guess.
I'm obviously hoping to use the 6mm as that saves expense on running more cable, but if its no good then I'll get some 10mm I guess!
Thanks in advance!
15A, 23A, 29A
Thanks in advance!
