hot water boiling hot
10 Dec 2006
Sheffield
Hello
I have a y plan central heating system with pump and three way zone valve,problem is when i have heating on only, the hot water heats up as well
but its really hot ,ive been told it could be my zone valve what do you guys think.
Thanks in advance.
When you have the ch only on, does the pipe from port 'B' of motorised valve that goes to hw cylinder also heat up?
Hi HERTSDRAINAGE2010 the stats set to 60 also the pipe coming out of the cylinder to the zone valve is very hot .
hi guys yes i do have an immersion and the pipe from cylinder to valve is hot when only ch on.
If the pipe from cylinder to valve is heating when heating only on, the valve is faulty. Sounds like it's not motoring over to heating only.
Just a new motor head (depends on the make and age of valve though) saves having to change the whole valve and draining down the entire system!
