Hot Water Conundrum!
30 Oct 2003
Hi, I am having problems with my Valliant Combination Boiler, and hope you can help.
I live in a flat and the hot water does not work in the kitchen.
The hot water works in the bathroom, infact when I turn the tap on in the bathroom sink the water is so powerful it leaps out of the sink. In the bath the tap is larger and water flows slower but the how water still works.
However in the kitchen the flow rate is as slow as treacle, does anyone know where does the power goes ? I gues if the flow rate was high I would get hot water ?
Thx
Mike
Hi Chris, I guess that would make sense as flow rate is very slow, do you think the tap is the most likely place for any blockage ?
Hi, I unscrewed the spout but had no luck, it was completely clean. It seems very strange to me. The bathroom tap is like a firehose, the bath is slow (maybe too slow even though it is a bigger tap), and the kitchen is hardly almost a trickle.
Do you think I need to start pulling the walls apart ?
God No !
Has this problem only occurred recently ? ( Ie you've not had a new kitchen tap or anything ) - If it has its probably a trapped washer or something in the body of the tap
Do the tap handles turn easily ?
Hi Chris/Liam, after going into the kitchen armed with a hammer I found out that the hot water tap under the sink was not turned on properly. My fiance thinks I am a DIY genius, thanks for your help!
