Hot water cuts out
25 Mar 2007
Wiltshire
Dear all,
Please help me with some advice on my Worcester 9.24 Electronic Combi boiler. I have never had to deal with boiler problems before and I am unsure what to do.
Previous minor problems include consistent fall in pressure over several months which I would correct periodically by turning the valve and raising it again.
Now when you turn on the hot tap or shower the boiler will light up 'demand' for a short while then shut off again providing nothing but freezing water.
Central heating is on a timer and seems to be fine, hot water demand appears to work when central heating is on and hence already providing hot water.
The boiler is approx 13 years old.
Can you please advise me if you think this is a major fault or not? Should I get an engineer out to have a look or is it something simple I am doing wrong?
Is it worth joining one of these breakdown cover schemes provided by British Gas or npower??
Please help I really don't know what to do??
Many thanks :?
Are you in Andover?
It sounds as if your diverter valve is failing! You can look at it and see if the pin is moving and operating the switch when the DHW flow rate exceeds 2.5 li/min.
Its very questionable if its really worth repairing. It would cost about £106 to repair or £190 to replace in London. In Andover you will be subject to fewer engineers and some dont like repairing older boilers which are better replaced.
But even after a repair it will still be a model nearly 20 years old !!! They do seem to be a long lived boiler but spares are starting to become harder to find.
Agile said:
Are you in Andover?
Are you f*cking nuts?!
Agile said:
But even after a repair it will still be nearly 20 years old
I said the MODEL was nearly 20 years old ! Not his boiler which he says is only 13 y.o.
Why dont you read what I write?
And Tim, I really do not appreciate your bad language!
No you didn't.
I read it, and I quoted it. In the meantime you changed it.
You do it all the time - stop trying to pretend you didn't.
Well f*ck off then.
Thanks Tony,
I am not in Andover - I have booked an engineer to come and have a look as I really need some hot water - have to see what they say I suppose.
Thank you for your advice.
