@wardr77 , if it's got to the point where the feed/vent is attracting a magnet then it's time to get it cut out and replaced, a cleaner won't be able to break that amount of hardened magnetite down I'm afraid. 5 gets you 10, that if the restriction is cut out and replaced then the pumping over will cease. If not then there's other system issues.
If you are leaving the x400 in the system for a while before that section is replaced then I'd just leave the pump set where it is just now and let the cleaner slowly work it's way around. Any higher speed on the pump and all you'll probably do is increase the amount of pumping over, thereby increasing the amount of dissolved O2 in the system water and all that'll do is promote more corrosion IMO.
