Have just completed the following sequence:
Turn CH and HW off
Open Bypass stopcock
Close all TRVs (ie minimum temp setting) on rads
Turn pump from top speed (3) to minimum speed (1)
Turn CH thermostat to max (30 degrees C)
Open TRV on nearest rad (bedroom) to full (max temp)
Close bypass stopcock
Turn on CH at control box
Switch pump from low (1) to high (3) - hoping to give the system a "nudge"
Try again with different radiators.
Try again but leave pump set to (3) all the time.
Have noticed that the boiler initially fired up but doesn't seem to be bothering now unless I turn up the temp setting on the boiler itself.
Unfortunately none of the radiators got hot (the bypass did though) the pump is extremely hot.
Also there was a comment earlier about 15mm pipes. Whilst the main kit around the valve etc is either 22mm or 15mm, the radiators are all much smaller than this.
Will check the orange wire next I think.
Back soon.
Turn CH and HW off
Back soon.
