Hot water on - reverse flow ? into CH
5 Jul 2006
Kent
S-Plan system.
When HW on, radiators get hot. Checked motorised valves, they appear to be OK.
BG engineer reckons the fault is with my return pipework which is not covered by their servicecare agreement.
Any ideas what needs doing/where to look to resolve it ?
Also, would it be worth changing the manual bypass to an automatic bypass ?
i would say you have probably got two returns on the radiator pipework back to the primaries causing reverse circulation.
by the looks of it they'll be under the floorboards.
thanks - I was considering changing to abv to make the system more "efficient", not to solve the reverse circulation issue
sort the problem out first, then add your goodies unless you like cooking in the summer.
should the bypass terminate in the return where it does, or should it terminate under the floor with the rads/hw return in a "common" return
what is the gate valve on the hw return for - its doesn't move
wheres the cold feed.
You sure that blue valve is not letting by.
Has any rads or work been done recently.
cold feed - on other side of airing cupboard I believe
blue valve - yes checked it - from cold, there is no heat on other side of valve - when opened manually, pipe gets hot straight away
have only been in house for 4 months, no work done by me
so would adjusting this prevent reverse flow (without breaking anything else !!)
if ya can find the return pipework from the radiator circuit ya could fit a check valve which might sort it
Does it look as though a radiator has been added anywhere, maybe a newer rad.
