Hi guys we live in a bungalow that has gravity fed hot water, and we have just fitted a new bathroom at the bottom end of our bungalow, but there is no pressure in the hot water taps, so basically i need to know can i just fit a single feed shower pump after the hot water cylinder to boost the pressure, if so what would be the recommended size and do i need a special valve on the cylinder, the bathroom is about 30 meters from the cylinder and is fed by 15mm pipes. Any info would be helpful, and any idea of a cheap pump supplier??
thanks
whitie
thanks
whitie
