You can't fit a pump on the mains (combi system) above 12l/min which wont help much. Using the showers one at a time or fitting an electric one are the easiest options.
What size is the combi boiler? There are Raindance shower heads which are aerated consuming 9 litres minute mixed hot an cold. So a good sized combi can just about do two of these showers.
Best have a full bore main stopcock and a dedicated 22mm pipe from the stopcock to the combi. A tee at the main stopcock to all other cold outlets. Piping up the hot and cold water pipes properly is important in any mains pressure system. Shower is king - all pressure/flow must be directed to the shower. Balancing the hot and cold system by pipework, aerated taps and outlet flow regulators is essential.
That is a good point. The aeration of the Raindance at 9 litres a minute, mixed not & cold, give the impression of a drencher. I have had combis fitted with two Raindance showers with them coping.
